Whirlpool Fridge Ice Maker Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 08-22-2007, 12:34 AM   #1
Whirlpool fridge ice maker not working
I have a side-by-side Whirlpool refrigerator, model number ED5FHGXNQ00. The ice-maker has stopped working but the water dispenser works fine. The ice maker is in the freezer, not in the door. Any ideas?
hlewis77 is offline   Reply With Quote
Old 08-22-2007, 10:46 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I have a similar Whirlpool sideXside, and the same thing happened to ours recently. We had to have the ice maker unit replaced ($150 part and labor).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
The Following 2 Users Say Thank You to Mike Swearingen For This Useful Post:
sfraser (07-29-2011), yourbama3 (02-13-2012)
Old 08-23-2007, 01:05 AM   #3
AK Hardware
Looks like your fridge is not very old. Common problem is a clog inside the ice maker. It's a pain to do, probably easyer to get it fixed unless you have a long time to wait for a service call or live in an area without service. Anyway clog is most likely about an inch from the in take line inside the ice maker.
Take out the ice maker or turn off the freezer untill it thaw's then use a tooth pick or THIN ice pick to push the clog through to the actual freezing tray, wash out the tray and re start the ice maker.
good luck
Niel is offline   Reply With Quote
Old 08-25-2007, 12:16 AM   #4
Where is the intake line?
Neil,
Can you explain to me exactly where the intake line is, in the ice maker? I'm going to try and fix it but I'm not certain where to look. Thanks for your help. I appreciate it.
Holly
Old 08-26-2007, 12:19 AM   #5
RE: whirlpool ice maker
I would bet $ that the problem is the water inlet solenoid. The coil is defective or there is a piece of crap preventing the plunger from actuating.
playintennis5274 is offline   Reply With Quote
Old 08-26-2007, 05:26 PM   #6
Rewards Points: 258
Don't guess, or at least make a educated guess. Check out this site Take a little time to get comfortable with their uncommon format. It will grow on you.
fixitnow.com Have the make modl & SN handy
Docfletcher is offline   Reply With Quote
Old 08-29-2007, 09:54 AM   #7
Thanks everyone!
I popped off the cover of the control module and the gear was broken! I have no idea how that happened. I ordered a new one and will install it. Wish me luck. If it doesn't work, I'll be chatting again.
Old 09-06-2007, 12:23 PM   #8
It's fixed!
Thanks everyone! It was the control module and I am now making ice again. We are a happy household again.
Old 08-30-2011, 01:38 PM   #9
Whirlpool side by side can't reset water filter light
We have a Whirlpool refrigerator model #GS6SHEXNS00 that will not let us reset the water filter light. We changed the filter but can not reset light.
Bob Middleton is offline   Reply With Quote
Old 08-30-2011, 05:23 PM   #10
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Not sure if it applies to your specific model, but worth a try
Whirlpool - press the light switch 5 times within 10 seconds. If the fridge has a filter button, press and hold it for 5-10 seconds.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 10-29-2011, 12:30 PM   #11
The voltage to the icemaker is 59 volts; I thought it would be line voltage. Is this normal?
MarkPaquette is offline   Reply With Quote
Old 11-01-2011, 12:50 PM   #12
Whirlpool Icemaker Dispenser Not Working
I have a Whirlpoop side-by-side where the icemaker makes ice but the dispenser doesn't dispense. The water dispenses but not the ice.
jaxfry is offline   Reply With Quote
Old 12-10-2011, 10:44 PM   #13
Whirlpool Ice Maker not working
Same issue - ED25PS model ice maker not working. I removed it and examined it and the control module, but nothing obvious wrong - the control module looks OK as far as I can tell. Checked the water inlet valve with a meter on the two contacts and it reads open.
So, maybe the inlet valve solenoid is burned out? But, why doesn't the door switch cause the dispenser motor to run, or the dispenser eject the ice if you manually pour a little water in it?
Can anyone confirm that if the solenoid is burned out, the ice maker is designed to detect that and disable all other parts of the system? If not, maybe it's not the solenoid after all...
kbeckett is offline   Reply With Quote
Ice maker stopped working bragl01 Appliances 5 10-30-2015 06:56 AM
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 06:46 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 09:27 AM
