Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-05-2007, 08:59 PM   #1
Master Plumber
Whirlpool electric dryer won't heat
I have a Whirlpool electric dryer about 2 or 3 years old and it is not heating at all. What are the possible causes for this and the solutions? I also don't know where to find the model number. Thank you
jpplumber is offline   Reply With Quote
Old 12-05-2007, 09:23 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
The element went out just like a water heater. Not a hard fix but you have to take it apart to find out Find the element and look for a break if not then try a contuctivety test with a volt meter if there is a break you will have none.
Kingfisher is offline   Reply With Quote
Old 01-11-2008, 02:58 PM   #3
The best place to start your check is at the wall.
With a multimeter check to see if you have 240 volts.
Check the wiring in the dryer if the voltage at the wall is good.
Check the continuity of the element.
The model number should be on the front panel in the door area.
girltech is offline   Reply With Quote
Old 01-12-2008, 05:46 PM   #4
check the the saftey heater trip switch...first...
fridgeman is offline   Reply With Quote
Old 01-13-2008, 09:29 PM   #5
any updates ????
comp is offline   Reply With Quote
Old 01-13-2008, 11:21 PM   #6
Master Plumber
sorry, it was the element, thanks.
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
too much electric heat DIYtilIdie HVAC 2 07-08-2007 09:27 AM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 11:21 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
