-   -   Whirlpool electric dryer won't heat (http://www.diychatroom.com/f47/whirlpool-electric-dryer-wont-heat-14123/)
jpplumber 12-05-2007 07:59 PM
I have a Whirlpool electric dryer about 2 or 3 years old and it is not heating at all. What are the possible causes for this and the solutions? I also don't know where to find the model number. Thank you
Kingfisher 12-05-2007 08:23 PM
The element went out just like a water heater. Not a hard fix but you have to take it apart to find out:yes: Find the element and look for a break if not then try a contuctivety test with a volt meter if there is a break you will have none.
girltech 01-11-2008 01:58 PM
The best place to start your check is at the wall.
With a multimeter check to see if you have 240 volts.
Check the wiring in the dryer if the voltage at the wall is good.
Check the continuity of the element.
The model number should be on the front panel in the door area.
fridgeman 01-12-2008 04:46 PM
check the the saftey heater trip switch...first...
comp 01-13-2008 08:29 PM
any updates ????
jpplumber 01-13-2008 10:21 PM
sorry, it was the element, thanks.
