Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-10-2009, 08:32 AM   #1
Whirlpool ED25PQ icemaker not cycling
My Whirlpool ED25PQ was working fine and then we moved it to our new home. The icemaker fills up with water just fine, and cycled a few times but now doesn't do anything. It is full of water, but not cycling and making new ice.
Anyone know anything about this?
OG
oldguard is offline   Reply With Quote
Old 06-10-2009, 10:15 AM   #2
The ice is being made, but its just not being cycled, correct?
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues.
For more help check out AP Wagner Appliance Parts
jronimo is offline   Reply With Quote
Old 06-10-2009, 10:20 AM   #3
Yes, the ice is being made, but it is stuck in the icemaker, not the ice bin.
I can stick my finger in the ice maker, and it seems to be frozen, but it isn't dumping it into the bin and then recycling.
whirlpool icemaker and water dispenser not working pal723 Appliances 3 03-18-2012 10:50 PM
Whirlpool Gold Series Icemaker issues dirty dirk Appliances 2 05-15-2011 12:32 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 09:45 PM
Whirlpool Icemaker Stopped Working jablizz General Discussion 1 07-19-2008 09:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
