Whirlpool Dw GU2700XTSQ1 Not Cleaning Well - Appliances - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 09:06 PM   #1
whirlpool dw GU2700XTSQ1 not cleaning well
Hi, our WP Gold QP1V is about 24 months in use, increasingly the dishes are not coming out clean. Same dw soap, have tried different settings ie Pots & Pans, PowerScour - no change - any diy suggestions are appreciated - Thks
wendl is offline   Reply With Quote
Old 03-17-2010, 06:34 AM   #2
food left on dish's,plates etc seem greasy??.. if you haven't been scraping food from dish's it's probably blocked up[need service].--DIY=make sure top rack spray arm is going into port in back, other port closed, you could try Lemi-Shine' through a cycle....
Jacques is offline   Reply With Quote
Old 03-17-2010, 08:07 AM   #3
Rewards Points: 266
I don't care how good they say those things are at removing food. If the food isn't scraped off before they go in it accumulates in the drain and gums it up. I run it empty with powdered lemonade, could even be crystal light, to clean the buildup in the tubes.
Jim F is offline   Reply With Quote
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 08:04 AM
Cleaning evaporator coil BlueBSH HVAC 1 01-14-2010 02:39 PM
Relocating drain/trap in manufac. home for whirlpool, HELP!!! MikeVila Plumbing 7 12-10-2008 10:04 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 09:16 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
