Whirlpool Duet Washer Fabric Softener Drain - Appliances - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 05:25 PM   #1
My whirlpool frontloader washer, fabric softener drain will not drain. I have pulled out the dispenser and cleaned it; however, I do not know how to access the tubing to see it that is clogged. Can anyone help?
thanks much!!
Leilam1065 is offline   Reply With Quote
Old 12-12-2011, 07:49 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
not sure what you mean by fabric softner drain. Here is how your fabric softner dispenser works. Basically you have a reservoir that sits inside the the dispenser, when its time for your fabric softner the control board sends voltage to a water solenoid. Water comes into your reservoir and creates a siphoning action siphoning out all your softner. Usually when they do not work it is because they are gummed up with softner but since you said you took yours out and cleaned it , I would suspect that you are not getting the water into the reservoir. Maybe the solenoid is bad or maybe the board is not sending the voltage to the solenoid.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Horizontal Washer Drain AFTER Standpipe 3 inch?????? hammerlane Plumbing 23 11-01-2011 10:06 PM
How to add Utility Sink and Washer Drain to existing 4" obriendigital Plumbing 9 03-26-2011 07:39 PM
Re-plumbing a washer hookup and drain question troyman75 Plumbing 3 02-24-2011 10:21 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
