Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-17-2009, 03:10 PM   #1
Whirlpool Duet front loading washer drain pump
I'm receiving an error code, F21-- long drain pump. I removed the bottom panel, unscrewed the drain plug to remove the water (nothing caught in it) and removed the drain pump to check for a clog. I started the drain cycle manually and the fan on the drain pump does run, but water isn't pumping out.
The line from the drain pump to the drain itself looks clear. Any other suggestions?
Jrr1099 is offline   Reply With Quote
Old 04-08-2009, 02:57 PM   #2
I need to buy a new washer. Did the problem turn out to be minor?
How do you get the bottom (front?) panel off?
LG front loaders have a 1/4" drain hose behind a door on the front, next to the lint trap.
I wonder if all brands have a hidden drain ?
V=IR is offline   Reply With Quote
Tags
drain pump, washer, whirlpool
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 09:23 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
Whirlpool Duet tryinitmyself Appliances 4 03-17-2008 01:07 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
