Whirlpool Duet - Appliances - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 12:35 PM   #1
RFN-4A-LVN
Roofmaster417's Avatar
Whirlpool Duet
I have a Whirlpool Duet washer.Recently with the frigid temps the hoses froze.The hose connector assembly thingamajiggydealythingy froze and cracked.I replaced this part with a new one.Since replacing the part the washer is not working.Working I mean the lights on the soil setting side are not on and the power button when pressed will not function.My question is what could make this happen?How can it be fixed? And is there a sequence of a possible reset that I should use since I replaced the part? Like resetting the computer or something?Any help would be appreciated.
Roofmaster417 is offline   Reply With Quote
Old 02-06-2011, 03:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
since you are a PAckers fan I will try to help, not sure what is working and what is not. Push and hold power button, what happens. Any lights at all?
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Roofmaster417 (02-06-2011)
Old 02-06-2011, 04:33 PM   #3
RFN-4A-LVN
I pushed and held in the control/lock button for 3 seconds then held the power for 3 seconds and BOOM.It works,,,,,,,,,,,,,,,,I know that you didn't really help but due to the escapade I waltzed on I would have not went in and tried those sequences.Maybe the 3 second sequence was a fluke but now the wife can find something else to complain about.Thanks hardwareman.And again I apologize.
Old 02-06-2011, 04:47 PM   #4
#1 HAWKEYE FAN
thats what I was getting at, your power button is also the child lock out button when you hold it for three seconds.
Anyone have a Kenmore Elite / Whirlpool Duet washer? HVAC_NW Appliances 3 12-22-2010 09:57 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 02:57 PM
Whirlpool Duet tryinitmyself Appliances 4 03-17-2008 01:07 PM
