Whirlpool Dryer SHOCK - Appliances - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 09:14 PM   #1
Shortly after replacing my dryer plug (3 prong) it began to give slight shocks when touching various metal parts. I let it go because the shocks were not that bad (I know not good).
So recently the dryer belt broke and while replacing I decided to check the ground wire(s) clean the entire inside and do a visual exam of all the wires in the dryer. Everything appears to be connected correctly with no damaged wires. I figured it might have been a bad plug so I replaced that as well.
Turned the dryer on (without exhaust duct connected) and touched in the areas where the shocks had been occurring and nothing. Connected the exhaust duct, washed a small load of laundry, put in the dryer and when the load finished.................... got shocked.
I am at a loss as to what might be causing this.
Any help would be great.
dolemite is offline   Reply With Quote
Old 08-13-2011, 10:17 AM   #2
Rewards Points: 121
Does it feel like a static electric shock (you can hear that as well) or a shock from ac current?
readar is online now   Reply With Quote
Old 08-13-2011, 01:45 PM   #3
Did you check the plug again?
Master of Cold is offline   Reply With Quote
Tags
dryer outlet , dryer shock , electrical , shock
Lp conversion to propane whirlpool dryer 1judyb62 Appliances 1 07-24-2011 10:56 PM
Whirlpool Dryer belt Keith Corbin Appliances 1 06-16-2011 09:21 PM
Whirlpool gas clothes dryer not heating ??? What have I done Appliances 5 10-19-2010 12:19 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 04:40 PM
