-   -   Whirlpool Dryer SHOCK (http://www.diychatroom.com/f47/whirlpool-dryer-shock-113844/)
dolemite 08-12-2011 09:14 PM
Shortly after replacing my dryer plug (3 prong) it began to give slight shocks when touching various metal parts. I let it go because the shocks were not that bad (I know not good).
So recently the dryer belt broke and while replacing I decided to check the ground wire(s) clean the entire inside and do a visual exam of all the wires in the dryer. Everything appears to be connected correctly with no damaged wires. I figured it might have been a bad plug so I replaced that as well.
Turned the dryer on (without exhaust duct connected) and touched in the areas where the shocks had been occurring and nothing. Connected the exhaust duct, washed a small load of laundry, put in the dryer and when the load finished.................... got shocked.
I am at a loss as to what might be causing this.
Any help would be great.
readar 08-13-2011 10:17 AM
Does it feel like a static electric shock (you can hear that as well) or a shock from ac current?
Master of Cold 08-13-2011 01:45 PM
Did you check the plug again?
