Whirlpool Dryer LTE6234dQ0 No Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 09:46 AM   #1
Rewards Points: 1,552
whirlpool dryer LTE6234dQ0 no heat
My brother in law's electric whirlpool dryer LTE6234dQ0:
1. drum spins
2. No heating
1. I checked both lines and getting 120 from each to neutral and 240 v across both
2. checked for continuity (all had it) and jumpered all thermostat cutoffs and safeties with no heat
3. I'm assuming it is the the dryer timer. I checked for continuity on terminal BK to Rd and got nothing (supposedly, according to wiring diagram it should be continuity).
Any suggestions or should I order the $80 timer?
Thanks,
Bob
bob22 is offline   Reply With Quote
Old 11-05-2012, 10:18 AM   #2
JasonSm's Avatar
Is there a thermal fuse present?
It's out of my area of expertise, but I have had a similiar issue. I checked the thermostate on the heaterbox and then the fuse. My fuse was shot. I believe it was a $7 replacement and I was up and running.
JasonSm is offline   Reply With Quote
Old 11-05-2012, 10:19 AM   #3
JasonSm's Avatar
I have found good info here that may be of use to you. http://www.electrical-forensics.com/...hesDryers.html
Old 11-05-2012, 10:44 AM   #4
Thanks Jason.
I bypassed both of those and it did not seem as if the coil was heating up any.
Both also showed continuity (not open) so I assumed that they were both good.
That led to the timer being the faulty part.
Old 11-06-2012, 08:58 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
the timer is the last thing I would be looking at for a no heat problem. When you are doing your continuity checks are you disconnecting 1 side? Do you have the wiring diagram available? If all your thermos check out and your thermal fuse is ok then you need to refer to the diagram and check each leg of power going to the elemnet idividualy. One side will go through all the thermos. etc., and one side will go through the motor windings.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-07-2012, 07:56 AM   #6
Hardware,
Yes, all checks were done with both wires disconnected from terminals.
I did seem to lose one leg and that was the one from the timer as best as I could determine from schematic and wire tracing.
I've ordered the timer and we'll see if it is the problem.
Fingers crossed.
Old 11-07-2012, 08:05 AM   #7
JasonSm's Avatar
Good luck! I'm curious to see if that fixes it.
Warm regards
Jason
Whirlpool dryer WED5521SQ0 takes too long to dry ilyaz Appliances 5 09-03-2012 07:25 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Whirlpool gas dryer problem MetsJetsNetrs Appliances 3 12-20-2009 09:08 AM
Whirlpool electric dryer won't heat jpplumber Appliances 5 01-13-2008 11:21 PM
No heat gas dryer fireguy Appliances 3 11-18-2007 10:46 PM
