WHIRLPOOL Dryer Getting Very Hot On Backside - Appliances - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 07:57 PM   #1
Rewards Points: 266
WHIRLPOOL Dryer getting very hot on backside
I have a Whirlpool gas dryer model LGQ8858jQ0. Lately it has been smelling HOT. I checked the Lint trap and it was not obstructed also the Metal duct exiting the house was clear. So that has been ruled out.
Even running a load on Medium heat, The unit smelled very Hot so I pulled it out to have a look. The back panel could not be touched as it was that Hot.
What would be causing this dryer to overheat like this? i am assuming this isnt normal on medium heat???
What have I done is offline   Reply With Quote
Old 06-22-2013, 10:19 PM   #2
Roofmaster
Rewards Points: 2,210
Have you run the lint trap under hot water for a while to remove residual buildup from dryer cloths? Try it, although fro the sound of it you may have something more serious. You do not have a corrugated exhaust pipe right?
Old 06-23-2013, 08:18 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
When was the last time it was cleaned too?
Old 06-23-2013, 08:19 AM   #4
Rewards Points: 14,302
http://www.repairclinic.com/RepairHe...hot-LGQ8858JQ0
Old 06-23-2013, 11:46 AM   #5
Rewards Points: 266
tHANKS FOR THE REPLIES.
No corregated flex duct. 1 elbow off the dryer connected to 7' piece of smooth walled duct that exits the house.
The filter and the duct were the 1st things I checked. All nice and clean!
I saw joe's link earlier and was thinking the cycling thermostat.
I switched through the heat cycles- no heat, low, medium, and high heat settings. Even though it was on medium it seemed like a High heat issue- considering how HOT the back of the unit was.
With the back opened up, I turned the dryer on and was able to witness the cycling thermostat was working. On low heat, the burner would cycle on/off as expected once it got to a desired temp.
I put the back back together and ran a load of towels on Medium heat. Seems to be working now. maybe cycling the dial through the settings cleared something up???????
Will continue to monitor
convert whirlpool dryer from 4 to 3 prong? kevanalthuis Electrical 2 08-19-2011 07:40 PM
Whirlpool Dryer SHOCK dolemite Appliances 2 08-13-2011 01:45 PM
Lp conversion to propane whirlpool dryer 1judyb62 Appliances 1 07-24-2011 10:56 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 04:40 PM
