-   -   WHIRLPOOL Dryer getting very hot on backside (http://www.diychatroom.com/f47/whirlpool-dryer-getting-very-hot-backside-182303/)
What have I done 06-22-2013 07:57 PM
I have a Whirlpool gas dryer model LGQ8858jQ0. Lately it has been smelling HOT. I checked the Lint trap and it was not obstructed also the Metal duct exiting the house was clear. So that has been ruled out.
Even running a load on Medium heat, The unit smelled very Hot so I pulled it out to have a look. The back panel could not be touched as it was that Hot.
What would be causing this dryer to overheat like this? i am assuming this isnt normal on medium heat???
jagans 06-22-2013 10:19 PM
Have you run the lint trap under hot water for a while to remove residual buildup from dryer cloths? Try it, although fro the sound of it you may have something more serious. You do not have a corrugated exhaust pipe right?
Windows on Wash 06-23-2013 08:18 AM
+1
When was the last time it was cleaned too?
joecaption 06-23-2013 08:19 AM
http://www.repairclinic.com/RepairHe...hot-LGQ8858JQ0
What have I done 06-23-2013 11:46 AM
tHANKS FOR THE REPLIES.
No corregated flex duct. 1 elbow off the dryer connected to 7' piece of smooth walled duct that exits the house.
The filter and the duct were the 1st things I checked. All nice and clean!
I saw joe's link earlier and was thinking the cycling thermostat.
I switched through the heat cycles- no heat, low, medium, and high heat settings. Even though it was on medium it seemed like a High heat issue- considering how HOT the back of the unit was.
With the back opened up, I turned the dryer on and was able to witness the cycling thermostat was working. On low heat, the burner would cycle on/off as expected once it got to a desired temp.
I put the back back together and ran a load of towels on Medium heat. Seems to be working now. maybe cycling the dial through the settings cleared something up???????
Will continue to monitor
