Whirlpool Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 09:03 PM   #1
Whirlpool Dryer
I need some help!! My dryer was making clinging sound lately so I decided to open it up to see what the problem was. Upon opening I noticed that a piece of sheet metal (3.5in x 18in) had fallen from the top. It was attached by double sided tape. There is also a similar piece on both side panels and on the drum itself. What is the purpose of this sheet metal? I called several places (including the mfg) but they have no idea as it is not on the drawings. I want to re-install it so I am looking for a flame retardant double-sided tape. If anyone can tell me what the purpose of that piece is, it would be greatly appreciated. Thank you in advance.
tbar79 is offline   Reply With Quote
Old 08-27-2011, 02:15 AM   #2
whirlpool dryer is very usefull house hold item
Huntsville Home Improvement
albert15 is offline   Reply With Quote
Old 08-27-2011, 08:41 AM   #3
I took pictures so that you may have a better idea.
Old 08-27-2011, 09:09 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
those strips are typically used to prevent "oil canning" of the flimsy sheet metal sides and tops. I've seen the insides of many many dryers but I can't recall ever seeing that strip on the drum.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-27-2011, 10:09 PM   #5
Thanks for taking the time to reply. It does make a lot of sense. I also question why they would add one on the drum. Again, thank you. Much appreciated.
convert whirlpool dryer from 4 to 3 prong? kevanalthuis Electrical 2 08-19-2011 08:40 PM
Whirlpool Dryer SHOCK dolemite Appliances 2 08-13-2011 02:45 PM
Lp conversion to propane whirlpool dryer 1judyb62 Appliances 1 07-24-2011 11:56 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 05:40 PM
