Whirlpool Dishwasher Not Draining - Appliances - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 03:00 PM   #1
Rewards Points: 121
Whirlpool dishwasher not draining
So I just installed a Whirlpool dishwasher, WDF510PAYS. Easy enough, what could go wrong, right?
Well, it doesn't drain all the way, I mean the water is to the bottom of the door. I followed the instructions. The drain goes directly out, not thru the disposal, and I looped the drain up high in the cabinet. Same as the unit before.
Any ideas on what to check first? It does drain most of the water, and otherwise seems fine.
JoeLena is offline   Reply With Quote
Old 05-03-2013, 01:50 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
new dishwasher I assume? Did you extend the drain line any? Where the drain line hooks to your plumbing, did you check to see if it may be partially plugged. If it isn't something like that you may need warranty service.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-03-2013, 04:38 PM   #3
Rewards Points: 121
Thanks hardwareman. It is indeed new, it appears to drain for a little, then stops. Maybe drains during one cycle and not a later one? Anyway, the drain is the same as the one it replaced. I went ahead and scheduled a call for Monday, was hoping to solve before then, it it will be fine.
Dishwasher not draining properly llmercll Plumbing 15 02-08-2011 11:24 PM
Dishwasher draining & water supply Murphy522 Plumbing 2 11-18-2009 09:51 AM
Water Draining Slowly - Is it Because Dishwasher is Attached to Disposer? jweiner Plumbing 7 01-22-2009 10:01 PM
Help Dishwasher Draining Problem swicks15 Plumbing 2 09-21-2008 01:58 PM
