Whirlpool Digital Control - OOO - Appliances - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 01:34 PM   #1
Side by side GS6SHAXML00: Several months both displays went blank, light stayed on. Freezer and ice maker still worked, fridge was limping at 40deg the door seal had been VERY HOT since the display went out. The other night it no more cold in freezer or fridge. After reading on this site I replaced the control board, nothing happened. Then the starter relay replacement and the compressor started, but still no display and the door seal got VERY HOT real quick. The condenser fan didn't start until I pushed it with my finger. I don't know it it was suposed to start immeaditly.
What do I do now to get the digital control working? I've dot all the food in coolers on ice.
lasvegas101 is offline   Reply With Quote
Old 10-01-2011, 03:02 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
i don't think the digital read out is your problem. Is the condenser fan still running? anytime the compressor runs the fan should be running.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-01-2011, 03:05 PM   #3
No the condenser fan is not working unless I give it a push.....So I should replace it? But what about the digital control? Any ideas?
Old 10-04-2011, 06:14 PM   #4
Top of the Fridg side is where the digital control is. No display, no control. Inside of this unit is a little PC board that is most likely where the problem lies. Approx $180.00. Has anyone relpaced this item? I want to make sure I can do it before I take the it on. Board dosn't come by itself, I was told it has a number of parts that come with it, like the posts that fit into the control knobs.
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 07:46 AM
digital thermostat control for attic fan? seavlad HVAC 2 06-08-2011 06:18 PM
digital shower control memory valve leaking michaeldvo Plumbing 0 11-10-2010 10:15 AM
Digital Thermostat to control exhaust fan SmokinSparkie HVAC 0 10-01-2010 02:34 AM
Honeywell TrueSTEAM with TrueIAQ Digital Control mjbxx HVAC 11 02-01-2009 02:25 PM
