Whirlpool 50 Gal Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 03:12 PM   #1
Whirlpool 50 gal water heater
my whirlpool 50 gal.heater began to have issues after a construction co severed gas line. Furnace and stove are fine. Pilot on tank is visible (electronic ignition) but unit doesn't seem to command burner to ignite when hot water is drawn.
rays is offline   Reply With Quote
Old 02-16-2013, 03:21 PM   #2
Rewards Points: 13,468
It turns on only when the tempature drops below a set point.
A simple cheak to see if it will come on would be to turn the temp. up higher just long enough to see if it kicks on.
http://homerepair.about.com/od/plumb...rblsht_hwh.htm
If there was air in the line the pilot would not light.
Old 02-17-2013, 08:03 AM   #3
Rewards Points: 194
It sounds like there is air in the gas line which would happen after having the gas line severed.
Larryh86GT is offline   Reply With Quote
Old 02-17-2013, 08:23 AM   #4
SuperJETT's Avatar
Rewards Points: 156
^^ What Joe said.
SuperJETT is offline   Reply With Quote
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
whirlpool water heater THEBIGPUNN Plumbing 1 02-01-2006 08:31 AM
