Whirlpool 30" Gas Cooktop - Appliances - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 08:42 PM   #1
Whirlpool 30" gas cooktop
How do i remove this cooktop from counter without destrying it?
I am having granite installed and want to go back with the same cooktop.
There is an under counter gas oven underneath.
whirlydad is offline   Reply With Quote
Old 04-14-2013, 10:06 PM   #2
r0ckstarr's Avatar
Rewards Points: 2,064
Do you have a picture of it?
r0ckstarr is offline   Reply With Quote
Old 04-14-2013, 10:18 PM   #3
Yes. Attached...
Old 04-15-2013, 09:04 AM   #4
MarginallyQualified
Rewards Points: 2,464
You do the REVERSE of the installation procedure.
Find/use the install instructions to learn how it is attached and to what.
Old 04-15-2013, 09:08 AM   #5
Rewards Points: 14,306
Going to have cut off the gas and power, remove the oven, then there should be clips under the top holding it in place.
oh'mike (04-16-2013)
Old 04-15-2013, 08:15 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you will have to remove the wall oven first, on the under side of the cooktop there will be a bunch of clips holding it down
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-15-2013, 09:06 PM   #7
That's what I was afraid of! Well,
I guess a little work is better than paying $800 (yes, this is California!) for the granite installer to remove, demo and re-install!
Thanks guys for your input!
Old 04-16-2013, 06:54 AM   #8
Just an FYI... now is a good time to make sure it is installed to code.
Not sure what your local codes are, but I have seen several cook tops that are installed improperly with respect to how the gas line is run.
Definitely worth checking into.
oldhouseguy is offline   Reply With Quote
cooktop options, 30" or 36" smithk80 Kitchen & Bath Remodeling 5 07-26-2012 03:24 PM
wiring a whirlpool cooktop davidtyson Electrical 8 06-17-2012 01:58 AM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 03:45 PM
Installing a KitchenAid (Whirlpool) Cooktop Dennis Slater Electrical 3 10-29-2009 12:21 PM
