Whirlpool 29" Dryer Has No Power - Appliances - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 10:05 PM   #1
Whirlpool 29" Dryer has no power
Wife was doing laundry when she put her second load in the dryer nothing happened, no power. I'm guessing or at least hoping its just a thermal fuse. Vent was clean, nothing blocking it which would be my only concern regarding the thermal fuse. Maybe the heater element??? Am I on the right track.
nsb318 is offline   Reply With Quote
Old 05-14-2011, 11:50 PM   #2
Rewards Points: 212
check the breaker. I will be a 30 amp for an electric dryer. If it is an older home, check the fus panel and make sure there are no blown fuses.
bluebird5 is offline   Reply With Quote
Old 05-15-2011, 12:29 PM   #3
I purchased one of those cheap voltage testers and it looks like from what I can tell no power is coming from the 50 amp plug. Circuit breaker is not tripping either. Could it be completely shot?
PS...My other screen name was disabled.
nsb31875 is offline   Reply With Quote
Old 05-15-2011, 01:19 PM   #4
Rewards Points: 212
how old is your house? does is have a fuse box?
Old 05-15-2011, 01:49 PM   #5
House is 32 yrs old. It has Square D circuit breakers. They were updated within the last 10 years or so.
If it were a circuit breaker issue wouldn't the breaker trip? It did not.
Old 05-15-2011, 02:10 PM   #6
Rewards Points: 212
well is depends. If you have a house with only breakers and no fuse panel, then th breaker should trip. Some houses have fuse panels and breakers. in that case the fuse will blow before the breaker trips.
Old 05-15-2011, 02:16 PM   #7
No fuse panel anywhere. I may shut the main off and take the breaker off anyway to inspect.
The guy at the Hardware store told me the thermal fuse is just for heat and would not affect the overall power of the dryer but the heat only.
Old 05-15-2011, 02:59 PM   #8
After witnessing my life flashing before my eyes trying to check the current I found the problem. The problem lies in the door. For some reason the door indicator isn't allowing the dryer to run. It looks like the door is closing all the way but for some reason the door indicator is not letting the dryer run. I have to push the door hard and almost cave it in before it will run. Would you happen to know why it would do this?
Old 05-15-2011, 04:02 PM   #9
Rewards Points: 212
maybe somone slammed the door and jammed something. might have to do a little jerry rigging. or replace the faulty parts
Old 05-15-2011, 04:20 PM   #10
the Musigician
DangerMouse's Avatar
nsb318 is still an active account.
DM
Old 05-15-2011, 04:25 PM   #11
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
sounds like you need a new door switch
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
need instructions on replacing a Whirlpool refrigerator power cord please. ChrisC30 Electrical 2 03-10-2008 10:59 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
