Whirllpool Refrigerator Broken Water Line Due To Heat - Appliances - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 04:36 PM   #1
Whirllpool Refrigerator Broken Water Line due to heat
I have found that the plastic water lines at the back, bottom, break due to over heating and denigration of the plastic. Any solutions?
drrjstull is offline   Reply With Quote
Old 09-05-2009, 10:42 AM   #2
Have read this about PVC but not seen it. Perhaps this is why I have read others prefer copper and stainless braided only.
Can you improve ventilation behind the unit?
Chemist1961 is offline   Reply With Quote
Old 09-05-2009, 11:27 AM   #3
Fan had stopped
I noticed that the fan had stopped running. When I pushed the fan blade it began spinning again.
Old 09-05-2009, 12:45 PM   #4
fan issue would generally be an indication of dead spot or dirty contact surface on the motor
Old 09-05-2009, 12:54 PM   #5
Thanks!
Thanks!
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Blockage in kitchen water line. Local Yokel Plumbing 6 03-18-2009 11:34 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Underground Hot Water Line st940692 Plumbing 15 10-15-2008 02:04 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
