When To Turn Off Dehumidifier In Basement - Appliances - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 10:00 AM   #1
Rewards Points: 154
When to turn off dehumidifier in basement
Hi All,
When is it OK to turn off the dehumidifier in the basement. Is there a certain temperature that needs to be reached?
TIA.
llckll is offline   Reply With Quote
Old 10-06-2011, 06:29 PM   #2
bubbler's Avatar
Rewards Points: 256
Usually people run them to a certain RH, relative humidity.
I'm not sure what temperature you're thinking (high or low) ... I leave mine on 24/7, it turns itself on/off based on humidify. I have it set for 65% which is about as good as I can get w/o it running almost constantly, and of course its duty cycle depends on outside conditions--if it's raining outside it will run more. If it's cool and dry it will run much less.
My basement isn't finished, but it will never cold enough to damage a running dehumidifer, if it does I've got bigger problems in the form of frozen pipes and congeled heating oil.
bubbler is offline   Reply With Quote
Old 10-06-2011, 06:52 PM   #3
Rewards Points: 268
I have mine set at 60% RH, it cycles about every 2 hours, depending on weather. Newer models can run down to about 45 degrees F or so (so my manual says). But it should be nice n dry (and -20f) here before my basements gets below 55f.
Marqed97 is offline   Reply With Quote
Old 10-08-2011, 09:57 AM   #4
hmmm, I've been a little curious about this too. I usually have mine at 65% as well because that seems like as low as I can go while still letting it switch on and off. Much lower and it's running near constantly which gets quite expensive.
mnliberty is offline   Reply With Quote
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 04:26 AM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
