What Size Flex Gas Line To Stove? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 08:27 AM   #1
what size flex gas line to stove?
I am replacing the steel flex gas line that goes from the hard gas line to the back of the range. I have propane. The replacement I bought is 1\2" and says it's good for gas ranges. The line I am replacing is 3/8". Can I use the new 1/2" flex line (with the correct fittings) in place of 3/8"????
jtrom is offline   Reply With Quote
Old 04-08-2013, 08:32 AM   #2
Rewards Points: 14,306
Bigger is better in this case.
Make sure to use the yellow teflon tape or gas approved pipe dope and check for leaks!
There's also suppost to be a gas shut off there where it comes out of the wall before the hose.
Old 04-08-2013, 09:06 AM   #3
Thanks Joe. I do have a shut off right there and have some Locktite pipe sealant that is approved for gas.
Old 04-08-2013, 10:53 AM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
If the fitting on your gas line is 3/8" then I don't see how using a 1/2" flex hose will 'help' per se, but it certainly won't hurt. Now if there's a 1/2" to 3/8" reducer on your gas line I would remove that and hook up your flex line directly.
fetzer85 is offline   Reply With Quote
Old 04-08-2013, 12:07 PM   #5
Both ends (range end and hard gas line end) had 3/4" to 3/8" reducers. I am putting on 3/4" to 1/2" reducers to make the new flex line work.
Old 04-08-2013, 12:10 PM   #6
Always learning...
fetzer85's Avatar
Rewards Points: 262
Gotcha, that makes sense.
Old 04-08-2013, 03:53 PM   #7
Rewards Points: 744
Soapy water to check for leaks, right?
Seattle2k is offline   Reply With Quote
Old 04-08-2013, 11:27 PM   #8
FYI: don't use dope on the flare fittings for the flex.
hvac benny is offline   Reply With Quote
Old 04-09-2013, 06:39 AM   #9
A little pipe dope on the flare fittings and threads will not be a problem
paintdrying is offline   Reply With Quote
Old 04-09-2013, 07:00 AM   #10
Rewards Points: 2,066
Do NOT put pipe dope on flare or compression fittings no matter where you live. It has no value on a connection that's correct and only makes it aggravating for the next plumber. If you must put something on something put a couple drops of lubricating oil on the threads.
SeniorSitizen is offline   Reply With Quote
Flare unions and pipe dope when installing gas stove line BrainDoc Plumbing 1 09-11-2010 10:42 AM
Line size for Trane pomelo HVAC 1 07-15-2009 04:20 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Line set size for Central AC JoeFL77 HVAC 5 05-21-2008 09:23 AM
CSST gas line through ceiling/floor to appliance pcampbell HVAC 2 05-20-2008 06:36 PM
