What Is This Part Under My Range? - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 12:21 PM   #1
PatrickGSR94's Avatar
Rewards Points: 87
What is this part under my range?
When pulling out my range before tiling my kitchen floor, I found this attached to the wall behind. It looks like one of the oven feet slide into it. What is its purpose?
http://img.photobucket.com/albums/v3...c/IMG_6946.jpg
Checked here and it shows the part #231 in the diagram but doesn't list it in the parts list: http://www.appliancepartspros.com/pa...8625#d21468625
PatrickGSR94 is offline   Reply With Quote
Old 03-20-2011, 12:34 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It attaches to the wall, (or sometimes the floor) the rear feet of your appliance slide into it. This is to prevent your range from tipping forward when the oven door is opened and someone uses the open door for a shelf. I think they come with all of the light-weight units. Use it!
XXX
Old 03-20-2011, 01:02 PM   #3
Rewards Points: 87
Hope I can get it in the right place!
Old 03-20-2011, 01:07 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's why God makes rulers and yardsticks.
XXX
Old 03-20-2011, 04:37 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
its called an anti tip bracket and is a mandatory accessory to your range courtesy of the U.S. government.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-20-2011, 10:45 PM   #6
Rewards Points: 87
looks like the tile has made the bracket holes too high to get to the wall bottom plate, and of course there are no studs directly behind either rear foot. Hollow wall anchors?
I opened the oven door and pressed down a good bit and could not make the range tip at all.
Old 03-20-2011, 11:17 PM   #7
#1 HAWKEYE FAN
exactly, I would guess 90 % of those things end up in the trash. I am not telling you not to put it on I'm just saying. The best way would be to get a mason bit and drill through the tile and run your screws into the sub floor
Old 03-21-2011, 12:03 AM   #8
Rewards Points: 87
Tiles are on concrete slab on grade
Old 03-21-2011, 09:36 AM   #9
Rewards Points: 22
Just drill new holes in the bracket.
Old 03-21-2011, 09:45 AM   #10
#1 HAWKEYE FAN
use tapcons into cement
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 11:35 PM
Coal range repair giantstag General DIY Discussions 4 12-09-2009 03:33 AM
Receptacles Behind Gas Range Install - Question IIchrisII Electrical 4 07-27-2009 09:37 PM
Range outlet required? A for Effort Electrical 6 07-21-2009 08:15 PM
Range receptacle install for SE cable run buhockey Electrical 2 03-11-2009 11:56 PM
