What Is The Best/proper Method On Affixing Dryer Duct - Appliances - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 05:22 PM   #1
Rewards Points: 288
What is the best/proper method on affixing dryer duct
Just finished doing the run of dryer duct ....
I did a couple brushes of mastic on the corner pieces just to seal it up.
What is the correct/best method on securing the duct runs..
While foil seems to be the universal answer, I recall reading somewhere which suggested that even the foil glue does harden over time.
Not a fan of clamps, as you need to tighten it up a bit just to snug the connections up. In order to *snug* it up, it does ~pinch~ the metal in a bit.
Pros, what is/are the best way to secure dryer ducts.
mobiledynamics is online now   Reply With Quote
Old 09-18-2010, 06:11 PM   #2
HVAC / Plumbing
Tape & mastic Last resort clamps
kenmac is offline   Reply With Quote
Old 09-19-2010, 01:57 AM   #3
No Hacks Allowed!
Try this 4" Plastic Quick Fit Dryer Elbow Kit by LAMBRO, Part #3003L, less than $10.00
This plastic elbow fits snugly (with no clamp needed) onto the crimped dryer exhaust pipe using a wide rubber gasket. The elbow will also fit snugly onto the dryer vent hood (thru-wall vent pipe) if the vent pipe is crimped.
There is very minimal air leakage on this plastic elbow unlike the blow-by through the numerous seams on a cheapie aluminum elbow. I also recommend that you use a corrugated aluminum flex pipe kit as depicted in the photo below.
Take your time using this type of dryer vent pipe as you attempt to thread it onto the split threads on the plastic elbow. It may take a lot of pushing, twisting and finessing to get the vent pipe to bite onto the elbow threads. Gripping the pipe too firmly while attempting to force the elbow threads into the vent pipe will put a dent in the vent pipe. Just take your time and don't manhandle the aluminum vent pipe using a gorilla grip.
I use two of these elbows on my dryer exhaust pipe as well as a vent pipe kit. It works great.
LAMBRO DRYER ELBOW KIT DETAILS:
No Clamp needed, Rubber gasket secures elbow to dryer or vent hood.
KIT CONTENTS:
1 - Plastic 90 degree elbow with rubber gasket inside one side.
1 - 4" metal worm gear clamp
You can find the dryer elbow at LOWE'S, or purchase it online. Search for "Lambro 3003L" and you will find several internet sites have it for sale.
You can purchase a vent pipe crimper and a flex pipe dryer vent kit at most any big box home improvement store.
LAMBRO 3003L Dryer Elbow, less than $10.00
Aluminum Flex Pipe Dryer Vent Kit, 4" x 8', less than $15.00
Malco-C5XXX-Pipe-Crimper, less than $30.00
Good luck!
NoHax is offline   Reply With Quote
Can bathroom exhaust and dryer share same outside duct? benze HVAC 17 09-08-2010 02:24 PM
Using existing duct for dryer and fan in basement.. faromic HVAC 3 03-10-2010 06:12 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Hole in my dryer duct... QuattroStylez Building & Construction 6 11-30-2008 04:11 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
