Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-02-2013, 07:15 PM   #1
Westinghouse furance will shut off with top door on.
two year old Westinghouse furnace will shut off after a time with top panal closed take panal off and it starts up. Two different Furnace repairman have no idea what causes it. It seem i alway have the weirdest problems
Mike Quast is offline   Reply With Quote
Old 02-02-2013, 11:17 PM   #2
Make sure the upper door is not pushing the lower door off of the interlock switch.
danpik is offline   Reply With Quote
Can you solder within an inch of a closed shut off valve? amodoko Plumbing 17 08-16-2012 01:29 AM
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 03:47 PM
No main power shut off vab53 Electrical 26 06-12-2010 03:51 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
