Water Valve Will Not Shut Off - Appliances - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 12:17 AM   #1
Water valve will not shut off
I have a Frigidaire Z(FRT18L4JB1) refrigerator with an ice maker. The ice maker has never been used. I connected water to it and the water valve did not shut off so it kept filling the ice tray then the freezer compartment. I ordered a new water valve and installed....same result of valve not sealing off. I tried a valve from another refrigerator. It leaked by as well. I replace the puncture type water valve under the sink with a "T" and in line valve. Still the same result. Just connecting the water to the valve with no electrical connection, each of the 3 valves leak by. Please tell me what I am missing! Thanks, Scott
smcpherson is offline   Reply With Quote
Old 05-18-2011, 04:50 AM   #2
Water pressure holds that diaphram in valve closed..you need at least 20#. hooked to well water or RO system?
Jacques is offline   Reply With Quote
Old 05-18-2011, 09:55 PM   #3
It is on city water - no well or RO.
Thanks for your help.
Scott
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How to Find and Shut Off the Main Water Valve PUTP Plumbing 16 01-08-2011 09:35 AM
Water Shut Off Valve and Tree Roots norulez43 Plumbing 3 11-17-2010 11:30 AM
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 04:01 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
