Water Under Vegg Bins Ge Gfss6kkxass - Appliances - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 06:47 PM   #1
water under vegg bins ge gfss6kkxass
water under veggie bins in ge side by side refrig bottom freezer model gfss6kkxass how do i stopp this
repairme is offline   Reply With Quote
Old 05-03-2013, 08:10 PM   #2
DIY staff
Rewards Points: 7,174
I'm not an appliance guy--but I've had this problem before---pull out the drawers and look for the drain---clean that out and you will be fine---a vacuum cleaner might suck out whatever is clogging it---or a thin soft wire---
Old 05-06-2013, 12:53 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
you will have to remove the rear back panel of refrig section. You should then see your evap coil,under the coil is a drain trough and drain tube, most likely it is frozen over. Thaw it with a hair dryer and hot water.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
