-   -   water under vegg bins ge gfss6kkxass (http://www.diychatroom.com/f47/water-under-vegg-bins-ge-gfss6kkxass-178689/)
repairme 05-03-2013 05:47 PM
water under veggie bins in ge side by side refrig bottom freezer model gfss6kkxass how do i stopp this
oh'mike 05-03-2013 07:10 PM
I'm not an appliance guy--but I've had this problem before---pull out the drawers and look for the drain---clean that out and you will be fine---a vacuum cleaner might suck out whatever is clogging it---or a thin soft wire---
hardwareman 05-06-2013 11:53 AM
you will have to remove the rear back panel of refrig section. You should then see your evap coil,under the coil is a drain trough and drain tube, most likely it is frozen over. Thaw it with a hair dryer and hot water.
