Water Tube To Fridge... - Appliances - DIY Chatroom Home Improvement Forum
Old 04-03-2008, 06:53 AM   #1
Wrench please!
Send a message via Yahoo to Wolf_22
Question
Water tube to fridge...
Hi everyone. Sorry is this post is a bit naive or novice - my first post.
So I just moved into a house I'm now renting, and with the fridge I bought for 260 dollars - I can't wait to settle in. There's only 1 problem... I can't seem to figure out what the tube coming out of the floor for the ice-maker / water dispenser is supposed to connect to. There is a small plastic tube coming out of the back of the fridge, and while I assume that the valve-connector from the floor / wall is supposed to connect to this tube from the fridge, I have no idea HOW as the tube from the fridge is just that - a tube. No adaptor, valve receiver, nothing. Just a plain-Jane tube.
Is there an adaptor that I'm supposed to buy at Lowes or something for this? The "connectore / valve unit" coming out of the wall / floor looks like it may be a male end.
Any help on this is helpful. I'm not at my house right now (work), so I can't elaborate on details much more than what I have, so I apologize for any ambiguity.
Wolf_22 is offline   Reply With Quote
Old 04-03-2008, 07:10 AM   #2
jeff1's Avatar
Hi,
Refrigerator make?
Model#?
http://www.applianceaid.com/model.html Some model# helps.
1/4"?
Plastic, copper, SS?
1/4"?
How -most- ( not all ) water lines are hooked up...
http://www.applianceaid.com/waterline-instal.html
jeff.
Appliance Repair Aid
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 04-03-2008, 07:31 AM   #3
Wrench please!
Originally Posted by jeff1 View Post
Refrigerator make?
Model#?
All I can tell you (at the moment) is that it's a side-by-side.
1/4"?
1/4"?
Since it's the size of a pencil, I would say that it is 1/4". It's plastic and has nothing else on it.
Old 04-03-2008, 01:11 PM   #4
There should be a valve on the back of the fridge that the water line will connect to.
Is the plastic line that you see connected to that valve?
girltech is offline   Reply With Quote
Old 04-03-2008, 01:26 PM   #5
Wrench please!
There should be a valve on the back of the fridge that the water line will connect to. Is the plastic line that you see connected to that valve?
...If it is, it's inside the fridge. This may sound silly, but if the fridge had a tail, it would be this little 1/4" plastic tube that's sticking out with nothing on the end. That's the best way I can explain it without showing images. The only valve that is visible is the from the line coming out of the kitchen floor. It has a metal valve on it that (obviously) can be shut on and off. Otherwise, the back of the fridge is nothing more than a plastic panel.
At first, I thought the plastic tube coming out of the fridge was supposed to slip over the male end of that metal valve, but, as it turns out, the tube is small enough to slip INSIDE the metal valve.
I'm thinking it will be best for me to go and draw an image of it or take a picture of it and take that to LOWES or someplace like that.
Old 04-03-2008, 01:49 PM   #6
Can you still supply your model number?
It will be on a tag on the inside of the fridge section with the serial number or behind the kick plate under the doors depending on the age of the fridge.
Then I can likely help with the parts.
Old 04-03-2008, 01:51 PM   #7
Wrench please!
I'm going to get that when I get back home tonight. I'll try to post it tomorrow.
Old 04-03-2008, 03:42 PM   #8
jeff1's Avatar
Great
jeff.
JRAppliance
www.jrappliance.ca
Old 04-04-2008, 09:18 AM   #9
Wrench please!
Sorry... Turns out I lied to ya. I didn't get that model number, however, I DID go to a local hardware place in my town to get a "freezer" kit that apparently has everything I should need according to the hardware department man. I'll tinker with this tonight and let ya know how it turns out.
Old 04-04-2008, 12:36 PM   #10
jeff1's Avatar
Good luck with it
jeff.
JRAppliance
www.jrappliance.ca
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 01:35 PM
No Water Flowing To Fridge garyb123 General DIY Discussions 5 12-24-2007 12:28 AM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 08:16 PM
Tapping a water line for fridge Statecowboy Plumbing 6 10-12-2006 11:45 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
