Water Softener + Ice Maker = ? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 08:35 PM   #1
Rewards Points: 152
water softener + ice maker = ?
i am about to purchase/install/use my very first ever water softener.
i am wondering what, if any, issues i may have with the water usage by the fridge/ice maker ? its a bran new LG french door. i don't think there will be any. but i would like to know beforehand.
thanx
Fix'n it is offline   Reply With Quote
Old 04-15-2012, 08:48 PM   #2
Rewards Points: 12,868
Not even sure why your asking. The new ice maker will not be trying to make ice with iron stains in it. Which is a good thing.
Old 04-15-2012, 08:49 PM   #3
bbo
the only "issue" you may have is that it will lengthen the lifespan of appliances.
you've had a water hardness test done, right? I really need to get one done myself.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Techy (04-22-2012)
Old 04-15-2012, 10:06 PM   #4
We have a softener & fridge w/ ice maker and have had no problems whatsoever.
On a side note if you have a whole house filter, then don't bother replacing the filter in the fridge, just remove it if your unit allows you to run it without. Our fridge allows this and it's one less expense/headache/maintenance issue to worry about.
VIPlumber is offline   Reply With Quote
Old 04-16-2012, 08:50 AM   #5
If you don't have adequate pressure to the frig-you can have all kinds of problems. check your owners guide or LG's web site for info re this.
Jacques is offline   Reply With Quote
Old 04-16-2012, 08:47 PM   #6
Rewards Points: 152
thanx, folks. i ask, because i don't know. i would rather find out before, than after.
Old 04-21-2012, 10:04 PM   #7
Missouri Bound's Avatar
Are you saying that the refrigerator will be hooked up to a line that connects to water that has gone through the water softener? You aren't supposed to drink that water....ever. Same goes for ice cubes. Have I missed something?
Do you want it your way or the right way?
Old 04-22-2012, 08:36 AM   #8
Rewards Points: 152
really ? that is the first time i have heard that
please explain
Old 04-22-2012, 10:06 AM   #9
please explain
I guess some people throw the dice on that one, but everything I have ever heard is against drinking it. Every home I have seen with a softener has a seperate tap next to the kitchen faucet which is NOT run through the water softener for drinking water.
Drinking Soft Water from a Water Softener
Please check out this site.
Low water Pressure with water softener garden Plumbing 8 07-31-2012 02:03 AM
orange water from softener joemontana16 Plumbing 5 11-23-2010 07:34 PM
getting metals out of well water without a water softener? mlc28 Plumbing 6 11-19-2010 11:28 PM
Water Softener started regenerating when I was changing the water filter nicksergeant Plumbing 0 11-07-2010 07:17 PM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 11:51 PM
