Water Softener - Appliances - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 12:34 PM   #1
Water softener
Have a water softener that will not shut off & has been running for 12 hours.
Lulaboyd is offline   Reply With Quote
Old 07-08-2012, 01:25 PM   #2
the Musigician
DangerMouse's Avatar
Old 08-24-2016, 09:37 AM   #3
Rewards Points: 2
Re: Water softener
Hi Lulaboyd. When a water softener is continuously running to drain, it means one of two things has gone wrong. Either the piston is stuck in the 'drain' position, or the seals and spacers (the conduit that the piston moves through) is damaged.
UVBoy is offline   Reply With Quote
Old 08-24-2016, 09:09 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 880
Re: Water softener
Agree. We had the same problem but lucky enough to have it repaired under warrantee. The gears are 'plastic' and when a piston stuck it stripped a gear and the cycle wouldn't advance.
If you're on well and septic your running your pump and loading your septic unnecessarily - if you're on metered water, your adding to your bill. There should be a by-pass control on the unit and/or your plumbing. I'd by-pass the softener and turn it off until repaired.
lenaitch is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 11:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
