Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-23-2008, 12:37 AM   #1
Water pooling in bottom of GE Nautilus dishwaster
I have a "builders grade" GE Nautilus dishwaster, 3 years old. It runs OK for the most part but for some reason water will often pool in the bottom of it between runs. Any ideas? The drain line is not clogged, sure of that.
Plasmech is offline   Reply With Quote
Old 03-23-2008, 09:58 AM   #2
jeff1's Avatar
Hi,
Not a model#.
Fill valve may not be 100% shutting off and weeping in some water all of the time.
Not written in stone...but mostly clean water inside when not using the d/w is a fill valve issue, dirty water inside when not using the d/w is a drain issue.
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 03-23-2008, 11:20 AM   #3
Model number is: GSD3200J00CC.
Thanks for the advice. Is there an online store that sells parts for these things?
Originally Posted by jeff1 View Post
Hi,
Not a model#.
jeff.
Old 03-23-2008, 11:49 AM   #4
jeff1's Avatar
GSD3200J00CC
Water inlet valve - GSD3200J00CC
jeff.
JRAppliance
Old 03-23-2008, 11:55 AM   #5
Thanks. Is there a service manual for download somewhere?
Old 03-23-2008, 02:26 PM   #6
jeff1's Avatar
GE doesn't normally put manuals online.
For simple things, something that may help...
http://www.appliancerepair.net/apnet...h/foreword.htm
jeff.
JRAppliance
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water on bottom of furnace timkay2 General Discussion 5 10-17-2007 09:27 AM
Water pooling on tile shelf Texasguy Building & Construction 13 04-27-2007 08:14 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
