Water Not Going Into Icemaker - Appliances - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 01:27 PM   #1
water not going into icemaker
ice maker not getting water up the tube in the back of the refig water coming into
dianna4452C is offline   Reply With Quote
Old 06-24-2012, 01:36 PM   #2
Icemaker
MY ICEMAKER IS NOT GETTING WATER UP THE TUBE IN THE BACK i DO HAVE WATER GOING INTO IT.
Old 06-24-2012, 07:18 PM   #3
Rewards Points: 83
if water is not getting to the end of the tube there is a clog in the tube. Snake it out or replace it.
Protocol. is offline   Reply With Quote
Old 06-24-2012, 07:21 PM   #4
Rewards Points: 12,886
If there's no water coming out the line then it's a kinked hose or the saddle valve is messing up.
I just never use saddle valves. they tend to leak and plug up, I replace the shut off to the sink with one with two shut offs and to places to connect lines to.
Old 06-24-2012, 08:10 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
op needs to be a little more clear . Do you have water up to the water valve of the refrig? I read the post as water to the valve but not to the icemaker, which would mean either a bad solenoid in the valve, a frozen fill tube inside the freezer or an icemaker that is not cycling.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-24-2012, 08:38 PM   #6
We understood you the first time you posted. No need to shout.
VIPlumber is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Icemaker water wont shut off bigskyjen Appliances 2 05-20-2010 12:30 AM
