Water Not Cold From Water Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 07:53 AM   #1
water not cold from water dispenser
We noticed it a few days ago. The ice maker makes ice and the freezer is cold. But the water is suppose to be at 50F is coming out about 70F. I know there is a chilled water reservoir somewhere. So my question is what could be causing this? And how is the water being chilled? Thanks.
leodlion is offline   Reply With Quote
Old 06-24-2009, 11:18 PM   #2
The first glass of water will always be warmer because the lines come out of the water reservoir (located in the fresh food compartment) then under the refrigerator to the bottom of the freezer door. The water in the line from the dispenser to the point where the line enters the fresh food section will be room temperature. So if the refrigerator is cooling properly the second glass of water should be colder.
Last edited by Scuba_Dave; 09-30-2010 at 12:37 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 06-25-2009, 07:39 AM   #3
Thanks for the reply. I am aware that the first glass is not quite cold. I took three to four glasses and took the temperature from a thermometer. It was around 70-72F. The specs says it should be around 50F.
The question is where is the water being cooled? There is a chill water reservoir. Is this water cooled from the freezer as it passes thru?
Old 06-25-2009, 09:25 AM   #4
The water reservoir is in the fresh food section most of the time behind the vegetable bin.
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 09:16 PM
