Water Not Cold Coming Out Of Water Door Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 10:30 PM   #1
water not cold coming out of water door dispenser
The water that is coming out of the door dispenser is NOT cold. How do make the water colder?
freederkaye is offline   Reply With Quote
Old 03-19-2012, 10:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you can not make it colder, there is not setting for colder water. your refrig has a very small reservoir for chilled water. By the time you run a glass or two out your getting tap water.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-21-2012, 01:14 PM   #3
Rewards Points: 1,298
Define cold
danpik is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water from cold water pipe!! DIYhelpee Plumbing 6 01-07-2012 11:05 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
