Water Line For My Ice Maker Disconnected - Appliances - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 12:34 PM   #1
water line for my ice maker disconnected
I have the plastic line for my ice maker/water. I moved my Refridgerator and it broke. I am trying to figure out how to reconnect it. I tried using a pair of plyers to unscrew the piece to take the broken end of the line out but it doesn't come unscrewed.. HELP!
tll1971 is offline   Reply With Quote
Old 07-17-2011, 02:19 PM   #2
DIY staff
Rewards Points: 7,174
Take a picture---the brass compression buts unscrew--if you have a white plastic gizmo there is a release==
Old 07-17-2011, 03:01 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
how are you going to reconnect it until you fix it?
what piece are trying to unscrew from what part?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-17-2011, 04:25 PM   #4
can't get bolts to unscrew
Here is a picture, I need to try to get this unscrewed so I can reattach the line. There is still plenty of slack I think/hope it can just be reconnected
Old 07-17-2011, 04:43 PM   #5
you should be able to hold the bottom hex and unscrew the top nut with the tubing sticking out. you would be going counter clockwise to unscrew it but you need 2 wrenches or pliers so it doesnt unscrew from the valve on the fridge.
The Following User Says Thank You to DannyT For This Useful Post:
tll1971 (07-17-2011)
Old 07-17-2011, 05:37 PM   #6
#1 HAWKEYE FAN
you will not be able to reuse that, you can reuse the nut but you will need a new ferrell and compression ring to make a leak proof connection. Like DannyT said get 2 wrenches and you should be able to unscrew it.
Old 07-17-2011, 06:26 PM   #7
jschaben
Rewards Points: 502
If you'll excuse a butt in post. I'd recommend you go ahead and replace that plastic line rather than just cut it back. That stuff gets brittle with age and starts developing pin holes. Mine started doing that about it's 16th birthday. After repairing about the 3rd pin hole I got p...o....'d and ran copper pipe from the saddle valve to the refer.
Just a suggestion.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-18-2011, 04:26 AM   #8
Ditto to what's been said. just to add; that bottom nut is superfluous. just connect line directly to valve.
Jacques is offline   Reply With Quote
De-soldering main water line MikeKy55 Plumbing 15 01-29-2011 01:39 PM
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 06:31 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
