Water Leaking From Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 09:21 PM   #1
Rewards Points: 131
water leaking from refrigerator
I have a Maytag fridge that is just over a year old. It has an icemaker, but not a water dispenser. Lately we have been finding water on the floor in front of it, coming from the area of both front corners. The freezer is on the bottom and is the type that has a drawer that slides out. The fridge is above. I'm looking for any advice on what might be causing this. I emailed Maytag and they just said that they were sorry.
bucksone is offline   Reply With Quote
Old 06-28-2011, 10:40 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
check inside the freezer to see if there is ice on the floor of the unit, sometimes the defrost drain tubes freeze up and the water will run inside your freezer and form a layer of ice, after a while it will build up enough where the water will start to run out the door.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-29-2011, 08:14 PM   #3
Rewards Points: 131
Thanks for the reply, hardwareman. There is, in fact, a significant buildup of ice on the floor of the unit. How do I safely get rid of the ice without harming the fridge, and how do I prevent this from happening again?
Thanks.
Old 06-29-2011, 10:50 PM   #4
#1 HAWKEYE FAN
remove everything from freezer, get out a hair dryer. First remove all the ice from the floor , in the very back of the freezer is the evap. coil below the evap coil is a drain trough. Melt all that ice out until you can locate the drain hole. Clear the drain hole , pour hot water down it until you are sure it is flowing freely. Its not a fun task but necessary
Old 06-30-2011, 03:26 PM   #5
Rewards Points: 131
Thanks for the instructions, hardwareman. I'll give it a try. I was wondering, though, where does that drain hole drain to?
Old 06-30-2011, 11:33 PM   #6
#1 HAWKEYE FAN
into a drain pan under your refrig.
Old 07-01-2011, 01:27 AM   #7
Rewards Points: 131
I guess what I'm getting at is when I pour that hot water down the drain hole to clear it, should I expect said water to end up on my kitchen floor?
Old 07-01-2011, 11:13 AM   #8
Rewards Points: 131
New development! This morning we discovered that the freezer isn't freezing. A bunch of food has defrosted and had to be thrown away. That layer of ice is also melting and pouring out onto the floor. Could this be related to the original problem?
Old 07-01-2011, 12:00 PM   #9
Rewards Points: 131
Ok, I've cleared out the ice and poured hot water down the drain hole. We had to take what frozen food we had that wasn't spoiled over to a relative's freezer. I put a couple of bottles of water in the freezer to see if the freezer is working again. If they don't freeze, I guess I'll call a repairman.
Old 07-01-2011, 12:52 PM   #10
#1 HAWKEYE FAN
better call the repairman!
Old 07-02-2011, 11:14 PM   #11
These are just some of the things i would check from own experience. If after you pour hot water down drain tube and doesn't flow then it is plugged with either build up of dust at bottom end or plugged with bits of food in freezer part of tube. seen it a lot of times. Don't know what refrig you have but you can check your main coils if your freezer/refrig has a hard time cooling(especially on hot days) to see if they are packed with dust. I just take a vacuum and tape a small hose like a small section of garden hose to vacuum hose so i can get in between coils. if they are packed with dust then the fan can't push air through them to cool the coils down and frig won't cool like it is suppose to.
obsidian231 is offline   Reply With Quote
Old 07-21-2011, 04:42 PM   #12
Rewards Points: 131
I used a hair dryer and thought I had melted any ice in the drain tube. Unfortunately, a week later, the ice and leak returned. We called a repairman. He came and corrected the problem. I'm not sure exactly what he did because I wasn't there and my wife wasn't sure. The invoice just says "drain tube clogged." When she asked him what we could do to prevent this in the future he wasn't able to give any suggestions. He said this sometimes just happens.
Any suggestions to prevent this from happening again will be appreciated.
Old 07-22-2011, 09:22 AM   #13
most likely he took a flexible wire and pushed it through the tube to clear obstruction. You can buy a heavy duty large/wide plastic zip ties at most hardware stores that would work good to but measure and make sure it will fit in the tube before you buy. If you can find where your drain tube is at then you could take some plastic screen for windows and cut a piece and put it on or over the tube opening. The screen will still let the water drain but will filter the bigger chunks of food from getting in there and blocking the tube. I can't say for sure but this happens often and is a good money generator for repair/service calls so maybe that's why he didn't want to tell you. For preventive maintenance always make sure your frozen packages are sealed really good so food/crumbs cannot fall out .
Old 07-22-2011, 01:07 PM   #14
#1 HAWKEYE FAN
that would be the last thing I would ever recommend doing, you can not cover that small drain tube with anything and expect it to not freeze over with in a matter of days.
about the only thing you can do to prevent this problem is to make yourself a heat transfer strap that you attach to the heater and then insert the other end down the drain tube.
Old 09-05-2011, 11:02 PM   #15
Cool
Frigidare leaking but not clogged drain or ice buildup
Hello,
I'm responding to this thread as I have the same problem albeit a different refrig.
I've read a lot of stuff on the web and blogs which gave approaches on how to possibly fix a water leak in my refrigerator. Water leaks below freezer compartment into refrig after and/or during defrost cycle.
When I opened the freezer back panel I had no ice or frost on the coils (but water was dripping off them a little bit), I put a wire went down the drain hole in refrig and the areas in the rectangular "hole" in the freezer with no issues, I poured warm water with bleach down into the metal tray below freezer coils and it went all the way down to the drain pan in a second and I adjusted the refrig to lean more towards the back.
However, water still leaks but I believe drains are all clear.
One other comment - the refrig, during defrost cycle I believe, was very, very noisy for weeks before the leak started and now it's quiet.
Is there anything else I can do or must I call a repairman?
Thank you for your comments and thoughts!!
beachgall is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
