Water Leaking Out Left Side Vent(?) Of Dishwasher - Appliances - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 12:59 PM   #1
Water leaking out left side vent(?) of Dishwasher
Hi everyone.
GE Nautilus dishwasher (five years old) model #: GSD3200J00BB
I'm hoping someone here can give me some insight on just what's going on with our dishwasher, since I spent all night last night cleaning up the mold that's grown underneath it as a result of the water leak.
If facing the dishwasher, on the bottom left corner is where the Complete Water Valve (GE part 744) is situated. A black hose runs runs from water valve, up the left side of the dishwasher, then curls back toward the front in a candy can shape where it feeds in to a plastic piece with what appear to be two vertical vents. During the cycle, I know water runs through this black hose at key points (I disconnected it at the water valve, and it shot out during the regular cycle), but for some reason when connected, the water is trickling out of these vents in a fairly steady stream. Not all of the water trickles out of these vents, since the dishwasher runs through the entire wash cycle and drains with no problem.
The plastic part with the "vents" appears to be plastic-welded to the tub itself, so I have no idea if it's replaceable. Anyone with ideas on how to fix this and stop the water leak, please help.
Thanks in advance,
-B
Barkley Online is offline   Reply With Quote
Old 07-12-2009, 10:47 PM   #2
Here is how to fix this problem. First remove the black hose then insert a 5/16-drill bit into the hole that the water enters (where you took the hose off). Slowly turn the drill bit making the hole a little bit bigger.
Do not use a drill just turn it by hand or maybe a pair of pliers.
Also note that you do not need to make the hole much bigger not even enough that you would notice to repair this. don’t over-do-it simply take a small amount of material out at a time, try it and if it still does it do it a little more.
Also do not insert the drill bit more than 1-1/4” into the hole or you will risk punching a whole in the bottom of the funnel.
Last edited by Scuba_Dave; 09-30-2010 at 12:37 PM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
The Following 2 Users Say Thank You to applianceman For This Useful Post:
Barkley Online (01-14-2011), deathmechanic (05-31-2012)
Old 07-13-2009, 05:55 PM   #3
Also note that you do not need to make the hole much bigger not even enough that you would notice to repair this. donít over-do-it simply take a small amount of material out at a time, try it and if it still does it do it a little more.
Also do not insert the drill bit more than 1-1/4Ē into the hole or you will risk punching a whole in the bottom of the funnel.
For do-it-yourself appliance repair hepl visit http://www.appliance-repair-it.com/index.html
Thank you so much for the reply! I've been pulling my hair out to try and figure out what is going on with this dishwasher.
But one question before I try this: Is this something that could qualify as a tub defect? When I called GE in regard to this, I was told I have about five years left on the GE 10-year tub warranty, and that if this was a tub defect, they'd fix it.
Any thoughts?
Thanks again,
-B
Old 07-13-2009, 06:13 PM   #4
Well the funnel is directly connected to the tub and cannot be removed so it is possible but I am not sure.
Old 07-13-2009, 06:17 PM   #5
One thing you may want to check on is that warranty is probably only for parts and not for labor. The thing is they are going to do what I described in my first post because that is how GE recommends repairing that problem. In other words it is not something I just made up. My point being is that there would be no parts involved so it may not be covered. Look in your owners manual or call GE to find out on this.
Old 07-13-2009, 07:39 PM   #6
Thanks very much for your insight on this. I see what you're saying. My question on whether or not it would make a warranty void was actually based on something I was told by the parts person I spoke with(not technically-trained, by her admission) when I called GE. So rest assured, it wasn't that I was thinking maybe you made it up, I was just wondering if what I was told when I called GE about the part in question (that they do not sell) was something I would need to be concerned about. I didn't want to void anything that by rights they should be obligated to fix.
And I have used the 5/16 drill bit to route out the hole to the depth you indicated. It had to go in at a bit of an angle, due to the channel the black tube runs through directly above it, but I did notice some plastic shavings. I'll post with an update on how it does as soon as I can run the dishwasher through a cycle.
Again, thanks so much. I was truly getting nowhere with this until you repsonded.
-B
Old 07-21-2009, 07:36 AM   #7
that's an age old problem that can happen to any water fed appliance that uses an air gap. [assuming your water at tap is not 160+ and now funnel is warped also that the valve is good and the flow washer is metering the correct pressure] it's due to mineral deposits deflecting/restricting the water flow. that's why it worked fine for 5 yrs. when you cleaned the funnel with twist drill you eliminated them. the tub is only covered for defects in manf. try to prove that. that's why these long warranties are silly and only a sales gimmick. that tub will last forever......if that didn't fix it, try it again. as last resort; slowly turn shut off valve down while watching it fill [make sure you'll still get enough water]....that $200+/- d/w from HD is probably GE's best d/w for durability=imo.
Jacques is offline   Reply With Quote
The Following User Says Thank You to Jacques For This Useful Post:
Old 01-14-2011, 01:07 PM   #8
Talking
GE Nautilus Fill Funnel
Our 9-year old GE Nautilus dishwasher GSD3630 was also leaking out the left side. It was not obvious the leak was coming from the fill funnel until we pulled the unit out from under the counter.
We read the previous post regarding using a drill bit to enlarge the opening and remove hard water deposits, but my husband (and repairer) suggested we use vinegar before trying the drill bit.
We opened the door and placed a piece of duct tape on the inside of the tub to cover the hole where the water fills. Then, we gently detached the black fill hose from the fill funnel. Using a baster, we filled the hole with vinegar and let it sit for 30 minutes. We then removed the duct tape from the inside of the tub, letting the vinegar drain from the fill funnel.
Next, using a cotton swab dipped in vinegar, we swabbed the inside of the fill funnel hose area on the outside of the tub, then the inside of the fill funnel on the inside of the tub.
We then put everything back together and it works great! No more leaks!
slstoll is offline   Reply With Quote
Old 01-14-2011, 01:42 PM   #9
I attempted to use the vinegar solution, and also a lime/rust/calcium solvent (can't recall the name), but nothing short of slowly drilling out the funnel worked for me. I am VERY grateful for all the help I received here, and will definitely recommend this site to others.
Thanks all,
-B
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Ridge Vent Leaking 35thLE Roofing/Siding 5 01-08-2009 12:33 PM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
