Water Leaking From Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 10:39 AM   #1
Rewards Points: 27
Water leaking from fridge
I have Maytag refrigerator. French door style with freezer drawer on the bottom. I have been noticing water coming from under the bottom. I originally thought it was one of the kids being careless with the water or ice dispenser. It is not the water line coming into the back. What else could it be. I read online it could possibly be the freezer drain froze over, but I didn't notice any water puddling up in the bottom of the freezer. No puddling inside at all. Any help is greatly appreciated. Thanks
jjones1020 is offline   Reply With Quote
Old 09-08-2013, 11:25 AM   #2
The solenoid valve for the ice maker could be faulty...not fully shutting off between cycles
RoyalAcresRod is offline   Reply With Quote
Old 09-08-2013, 01:08 PM   #3
DIY staff
Rewards Points: 7,174
Three possibilities---that I know of--so until an appliance specialist shows up--check these.
1--The condensate pan under the fridge is leaking or miss aligned.
2. The drain hole in the bottom of the fridge is clogged
3 water filter is cracked or not installed correctly
D. the water feed system has a problem---
Pull out the fridge and start looking----
Old 09-08-2013, 02:49 PM   #4
Rewards Points: 152
I had a similar problem with my Maytag (bottom freezer door). The drain hole was frozen over and the defrost cycle would cause water to run out. Knocked out the ice, cleaned out the drain hole (had some crap in it) and been good ever since.
Used this video as reference:
burnt03 is offline   Reply With Quote
Old 09-08-2013, 03:42 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Take off the back bottom and see what is going on. I had the same problem. There was a little plastic pan on top the motor which was filled with water. I dump it. Good for another year. Now i think about i should probably check it again. LOL
747 is offline   Reply With Quote
Old 09-09-2013, 08:54 PM   #6
Rewards Points: 27
Just to update.... I took the back off and the drain pan somehow got a crack in it and a piece broke off allowing the water to run right out and onto the floor.
The Following 2 Users Say Thank You to jjones1020 For This Useful Post:
Live_Oak (09-10-2013), oh'mike (09-09-2013)
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
fridge leaking water thehvacguy Appliances 2 05-28-2013 07:47 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Water source from fridge from water heater? dankreboot Plumbing 11 07-12-2008 10:08 PM
