#1 |
water leaking from freezer
How To Turn Off Water To Freezer Ice Maker In Hotpoint Refrigerator?
#2 |
Normal function is to put ice maker arm in UP position. It could be a switch on newer fridges. This would tell fridge valve not to open/send water.
If water cannot be stopped, needs to be turned off mechanically. Pull fridge from wall, follow copper or plastic tubing to water supply source and hopefully there is a water shutoff valve to throw. This may turn off water in the fridge door too if that's a feature. If no shutoff, that leaves another shutoff somewhere else, possible the whole house shutoff valve so a repair can be made. |
#3 |
Hopefully we wil have a repair person today. If not... we will try and pull out frig as I am tired of getting up every hour all night to dump water!
Both being over 70 makes moving this big frig a problem but worth the try. I did empty the freezer this AM so on the right track. Thanks
| Display Modes | |
| Help My Admiral Refrigerator is leaking water | Cuwillis | Appliances | 9 | 03-22-2011 09:40 PM |
| No water draining into sump pit | aci4369 | Plumbing | 2 | 08-18-2009 01:17 PM |
| Testing 12 year old hot water expansion tank? | DJfixer | Plumbing | 2 | 01-01-2009 09:09 AM |
| freezer leaking into fridge - cannot locate drain hole | pro_DIYer | Appliances | 5 | 01-01-2009 12:08 AM |
| Leaking Rheem 60 gal Electric Hot Water Heater | aklkuno1 | Plumbing | 3 | 10-22-2008 11:13 PM |
