Water Inside Of Thermos Tip - Appliances - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 02:15 AM   #1
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Water inside of thermos tip
A friend of mine has a coffee maker with a thermos type pot. They would wash it in a sink full of water. Water had gotten inside between the outer housing and the thermos, sloshing around. Because the bottom was plastic I just drilled a little hole on the outer edge and it drained out just fine. Do not drill in the center! You will hit the thermos vessel. Just a tip if you have the same problem, dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
