Water Heater Won't Light - Appliances - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 06:24 AM   #1
Water Heater won't light
I have a 6 year old AO Smith propane water heater, model #GPSH 50-101. The heater wont light by itself and shows an error code that the system is in lockout.If I unplug the unit from the wall and plug it back in it tries to light 3 times and shuts itself off and shows the same error code.If I unplug the 3 wires that go to hot surface ignitor and sensor and plug them back in,it will light and work great. Do I need to replace these parts or could it be something else?
adfuhrer is offline   Reply With Quote
Old 12-10-2010, 06:09 PM   #2
Rewards Points: 5,336
Bad thermocoupler?
Ron
Old 12-10-2010, 06:18 PM   #3
Send a pict. Does it have a drain off of the flue. It sounds like a high effi unit. If so probel drain problem
Hixheat1 is offline   Reply With Quote
Old 12-12-2010, 10:07 PM   #4
what error code? it should have a list of all codes in the manual that came with the tank.
the_man is offline   Reply With Quote
Old 12-13-2010, 04:34 AM   #5
error code says system is in lockout
Old 12-17-2010, 03:26 PM   #6
Did you ever get this fixed?
Ron
Old 12-18-2010, 12:51 PM   #7
you need to turn the control knob to the pilot light mark so that when it lights it creates enough heat to cause the thermocouple to open ( let gas through) and then turn the knob to the run position...If that does not do it, you need a new thermocouple that usually unscrews from the main control... Be carefull, gas is nothing to fool around with if you are not to familiar with it.... good luck
gavinol is offline   Reply With Quote
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Pilot Light Won't Stay Lit on Water Heater jdolan HVAC 4 07-23-2010 04:42 PM
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 04:40 PM
Problems with water heater jwise Plumbing 11 02-26-2010 07:36 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
