Water Heater Trip Breaker/Reset - Appliances - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 03:47 PM   #1
I have a water heater (installed in 1995) in the house I bought 2 years ago. About 9 months ago, it stopped working. I looked and it tripped the circuit breaker for the water heater. I turned the breaker back on and reset the water heater (open panel + push reset button). It worked fine for 6 months. About 3 months ago it stopped working, but this time did not trip the breaker. I reset it, and it has been working fine since.
I suppose it is nearing the end of its' life, but wanted to see if anyone has had a similar experience or has any input as to what could cause it to stop working twice (trip breaker once), but work again after being reset.
Thanks!
lmark103 is offline   Reply With Quote
Old 09-28-2012, 04:19 PM   #2
Rewards Points: 13,450
Shut the breaker off and check for loose conections on the heater and the breaker.
Tags
breaker , heater , reset , trip , water
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
