Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-17-2006, 12:56 PM   #1
CJP
Water Heater - replacement info.
I have an Reliance - STA-KLEEN 805 Water Heater tank and wish to replace it since it is over 12 years old. To determine which is the appropriate replacment option (size access to area and height needs to be pretty close to 805, I need exact dimensions - is it 40 or 50 gal tank, what is the height (BTW - is the height measure from ground to the top or just the actual tank height) and diameter etc.
I have scaned the web and did not get that info.
CJP
CJP is offline   Reply With Quote
Old 11-17-2006, 04:14 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
When replacing a water heater, it is easiest to do by finding one roughly the same size. The height of the water heater from bottom to top and the width should match up with the existing plumbing and wiring.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
