Water Heater Not Draining - Appliances - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 03:11 PM   #1
A Kenmore "PowerMiser 12" installed 03/06.
Here are some PICS and an explanation of the problem.
Drain valve gradually stopped working. Obvious sediment build-up but where to go from here?
Did all the prelim...turned off gas, shut water input, opened pressure relief valve and a house hot water tap,etc...
As you can see I removed the top of the valve. This was with a full tank. I tried running a "bailing" sized piece of wire up it to dislodge the corrosion but it did little and met little resistance at all. I then hooked another short hose to where I removed the valve stem cap. I then preceded to pinch off the lower hose and blow air pressure into the newly attached top short hose. It gurgled and I could hear the tank bubbling from the air. I then stopped the air, raised the upper hose, and the lower hose would surge a bit, belch a few chunks (lower photo) and stop draining.
This will be a long day if I have to babysit it like this.
Where would you go from here?
Would removing this plastic valve and putting in a brass ball valve help?
Still how to get the water draining/flowing?
Is this drain valve at the bottom or does an internal pipe run somewhere?
thanks
TSHRED56 is offline   Reply With Quote
Old 01-23-2011, 07:03 PM   #2
Okay I got "lucky".
Removed the old valve without breaking it!:
Installed a way better option with many times more flow (for the big chunks):
Now draining much better:
Now I need to find out how to flush the corrosion out.
Old 01-23-2011, 08:11 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
turn the water on to the water heater and a lot of that crap will wash right out . you may have to run that wire up into the valve to dislodge all of it.
hardwareman is offline   Reply With Quote
Old 01-24-2011, 12:16 PM   #4
Rewards Points: 5,336
Do you have a hard water issue?
Ron
Old 01-25-2011, 08:29 AM   #5
That the old gas flex line you reused in 06?? there was a recall on them.
Jacques is offline   Reply With Quote
Old 01-25-2011, 08:31 AM   #6
If that 'sediment' was plastic, it's what left of your dip tube.
Old 01-25-2011, 08:41 AM   #7
Thanks for that heads-up!!
I will get it changed out pronto.
Old 01-25-2011, 08:42 AM   #8
No it was a brittle calcified substance that turned to powder when easily crushed between the fingers.
Old 01-25-2011, 01:03 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
That full flow ball valve that you installed is the first thing I install when I install a new water heater.
Brass nipple
3/4" threaded ball valve
3/4" MIP to 2/4" male hose adapter
Every 6 months or so. I hook up a hose and open the valve to blast out the sediment. I leave the water on to blow out under pressure.
Coastal South Carolina
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
