Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-16-2012, 07:11 PM   #1
water heater leak
anyone ever have a water heater leak from the top? i have lost them before when the bottom rusts out and they start leaking but this one is wet at the top at the bungs where the water lines go in and out. i have checked the lines and the fitings and they are good but the top of the tank is wet from the insulation by the bungs......
gwilkrrs is offline   Reply With Quote
Old 12-16-2012, 07:16 PM   #2
water heater leak
Got a picture?
Were dielectric unions used?
Old 12-16-2012, 07:21 PM   #3
water heater leak
Got a picture?
Were dielectric unions or nipples used?
Old 12-16-2012, 07:30 PM   #4
water heater leak
yep- i replaced the lines with new and waited and a week later had same resultswater heater leak-img-20121216-00180.jpg
Old 12-16-2012, 07:35 PM   #5
water heater leak
Your missing the proper nipple.
Here's a picture.
http://www.bing.com/images/search?q=...069532&first=1
Also if you over tightened those flex lines you may have crushed the rubber washer inside of them.
gwilkrrs (12-16-2012)
Old 12-16-2012, 07:39 PM   #6
water heater leak
never saw those nipples- been installed for 2 years now started leaking----if the are true nipples with threads on each end how is it conected to the tank side?
Old 12-16-2012, 07:52 PM   #7
Items wanted: Time
water heater leak
You're missing die-electric unions. Copper cannot connect to steel without them.
NiNe O is offline   Reply With Quote
Old 12-16-2012, 07:52 PM   #8
water heater leak
I'll bet someone threaded steel nipples into the bungs on that tank for you to attach those flex lines to. Any tank I have ever installed always has female threaded openings for the connections. The conectors Joe linked to are supposed to thread into them and then the water connections made to them. Hopefully the threaded openings on the tank are not too corroded to be usable.
danpik is offline   Reply With Quote
Old 12-16-2012, 07:55 PM   #9
Items wanted: Time
water heater leak
looks like those labor savers have some die-electric properties to them so scratch that.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Hot water heater leak? ddasher8 Plumbing 1 07-03-2005 06:00 AM
