Water Heater (Gas) Not Working - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 07:25 AM   #16
Originally Posted by Jacques View Post
that little thingie with the wires is a non-resetable safety cut-out. why did it cut-out??? if you don't want to call a plumber, i would at least call the Factory. you may have an un-safe condition.
Thats the piezio ignitor.
naehring2000 is offline   Reply With Quote
Old 02-10-2010, 10:51 AM   #17
when i said 'thingie' i meant that safety cutout on the burner compartment access door. it's there in case the burner compartment senses overtemp,not enough air flow,etc. when it trips it shuts down everything. -turns out it is resetable, but because it's a saftey device;you have to determine why it tripped. because it's new i wouldn't suspect scale buildup. you should probably post in the plumbing section. in any event you don't want to blow your house up.
Jacques is offline   Reply With Quote
Old 02-10-2010, 11:58 AM   #18
Thumbs up
Originally Posted by cprao View Post
When you say unit, are you referring to the house ? If yes, gas is coming to the house since my house heater is working.
If you are asking whether the gas is coming to the water heater or not, I don't know how to check this? Can you please let me know ?
Yes. the "unit" means the hot water heater, in this case. Only way (that I know to check for gas supply is to loosen the union on the supply line, with Two pipe wrenches. I doubt, though if you should undertake this endeavor. It's time to call a plumber or handyman.!
p.s.: Maybe I give up too soon?
spark plug is offline   Reply With Quote
Old 02-10-2010, 04:50 PM   #19
Rewards Points: 282
I guess.. this may be the reason.. When we were not getting a good hot water, I rotated thermostat knob all the way to clockwise.. The water was getting overheat.. probably that is what caused the trip..
I don't except scaling because I had a service guy to plush all the water.. and the water was very clean, no traces of scaling.. So I belive the trip is just because of over heat...
How do I reset this ? Any hep ? Is it something that I can do it ?
cprao is offline   Reply With Quote
Old 02-10-2010, 04:53 PM   #20
Rewards Points: 282
Thank you.. As you said, I don't think I would like to do this..
I will try to reset the switch, if I come to know how to do it..
Otherwise, my last resort would be - call a service guy..
Old 02-11-2010, 01:10 PM   #21
Hot water heater
Are you giving it enough time? Pilot lighting instructions usually require that you turn the thermostat to off for five minutes before commencing the pilot lighting sequence. Every time you move the thermostat counterclockwise, you may screw up the timing, and as a safety measure the boiler is not allowing the gas to come on. If you have the manual read it very carefully, and follow the directions precisely and it should light. If you don't have the manual, try calling the manufacturer or checking to see if they have instructions on the website.
If it has a piezo igniter, it may not even have a pilot light, but that is a pig with different lipstick. If it does not have a piezo igniter, than you will need a fireplace match or a barbecue lighter. Even then, lighting the pilot requires the patience of mother theresa combined with the piloting skills of Neal Armstrong. In fact, if he is available, I would try to get his help.
billy_bob_3 is offline   Reply With Quote
Old 02-11-2010, 06:56 PM   #22
Wink
Addressing the Second Paragraph; A regular kitchen match at the tip of a long-nose plier will do the trick. That's what I do when (occasionally) I have to re-light the pilot.!
Old 02-11-2010, 08:21 PM   #23
Hmm - are you sure you are not Neal Armstrong?
Old 02-11-2010, 08:36 PM   #24
Thumbs up
Why?! Because I fly in space. I'm firmly situated on Earth. What I said was, that if everything else checks out and you want to light the pilot of a water heater, ... Well. Why repeat. I think I said it clear enough...!
Old 02-12-2010, 02:29 AM   #25
Rewards Points: 282
Ok. After following the instructions, the pilot light comes off after several attempts of ignition but it does not stay on.
Instructions says - I need to hold the pilot set button for a minute and the pilot light should stay on even after releasing the button.
In my case, as long as I hold the button (almost 2 minutes), the pilot light stays on but the moment I release the button, pilot light goes off..
What would be my next step from here ? Any clue ? Since the pilot light is coming what I conclude is - 1) My ignitor is working and 2)gas is coming to the appliance.. Now what can be wrong here ? what should I be checking next ? Please help.
Old 02-12-2010, 03:24 PM   #26
Thumbs up
If you remember (or you can look it up). In one of the early posts on this thread, I said that even if the pilot (light) lights while you're holding the (Red) button, but doesn't stay on, it's most likely the THERMOCOUPLE. That is a safety device to prevent the gas from the pilot leaking if there is no flame, for any reason. But that device itself can fail. Then the solution is to replace it.
(Sorry. I can't post a drawing how that device works, but I'll try to describe it.)
There is a (bare) Copper wire, where one end is attached to the flame port. The other end is connected to the pilot gas valve. If that wire senses the heat of the flame, it will open the (pilot) gas valve. That's why the requirement to hold the button for one Minute. When you release, the wire should be hot enough to keep the valve open. If it doesn't, that part (The "Thermocouple") should be replaced.!
Old 02-12-2010, 03:48 PM   #27
Thumbs up
That is called a "Spill Switch". It "Locks Out" the burner when it senses carbon Monoxide, due to a blocked (exhaust) vent or chimney. !
Last edited by spark plug; 02-12-2010 at 03:50 PM. Reason: Added letter/word (a) for clarity!
Old 02-12-2010, 11:52 PM   #28
Rewards Points: 282
I pulled out thermocouple and planned to replace tomrrow with a new one.. Hopefully this works..
Old 02-13-2010, 12:38 PM   #29
Chaz
YO. "Seperated by a common language" . Hmmm, where have I heard that before.
Have ya' dug out yet?
If you come up to Maine again, you should write and I'll take you fishing on Moosehead Lake. I live on it.
CallMeChaz is offline   Reply With Quote
Old 02-13-2010, 12:50 PM   #30
Chaz
Hey, were you able to replace it? That should have solved it, unless you have a bad connection in your thermocouple circuit.
Depending on how it's wired, you may be able to jump past the thermocouple safety just to verify that the pilot stays lit. If memory serves, it's more of a mechanical thermocouple on gas units, and you may not be able to "fool" it. Anyways, you can't leave it that way--just long enough to test it.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 05:36 PM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 07:08 PM
