Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 07:11 PM   #1
water heater
How can I verify my water heater is getting power? Have replaced both therms and both elements and have had no hot water since replacing them.
frustrated! is offline   Reply With Quote
Old 12-24-2010, 08:21 PM   #2
Rewards Points: 1,418
Where the power wires first enter the water heater there are connections, usually wire nuts, where you can measure the voltage. First measurement, set your multimeter to 250 or more volts AC, then stick one probe inside each of the two wire nuts attached to the respective incoming wires. You should get about 230 volts here.
Next measure across the two terminals of each element. One should give a 230 volt reading. (Only one element is on at any given time, or both would be off when the tank is fully heated.)
Now turn the power off at the breaker panel. Set your meter to ohms. Measure across the two terminals of each element. You should get a value less than 100 (ohms).
A water heater must never be turned on until the inside is full as evidenced by water gushing from an open hot faucet upstairs.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
