Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 01:43 PM   #1
water heater
my water heater has started making whistling noise when heating. what is wrong? is it safe?
Chevy1964 is offline   Reply With Quote
Old 04-15-2012, 03:37 PM   #2
DIY staff
Rewards Points: 7,174
If the sound is coming from inside the tank---you may have a lime build up in the bottom of the tank--
If the noise is from the gas valve or burner---you may be nearing failure of the valve--
Where is the whistling coming from?
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
