Water Heater - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2007, 11:31 AM   #16
Hi jerry
You can buy a new hot water tank at any good building supply store, such as Home Depot, or you can go to a business that deals strictly with plumbing. Being as your tank is propane, you might have to search around a little, as they are not nearly as common as natural gas tanks. I do not know precisely what the difference is between them, I only know that they are not interchangeable. The tanks aren't hard to replace, but many jurisdictions require you to get a permit. If you aren't comfortable with the idea of doing the installation yourself hire a pro. Also, once completed, have a thorough gas leak check done, and I would also suggest you purchase a carbon monoxide alert, just in case the heater part of the tank is not properly vented to clear all the fumes out of the house.
Good luck
Gerry
Gerry Kiernan is offline   Reply With Quote
Old 10-12-2007, 03:31 PM   #17
Rewards Points: 123
I am sorry, my water heater is natural gas!
jerry1967 is offline   Reply With Quote
Old 10-12-2007, 09:56 PM   #18
No Problem jerry
Natural gas tanks are readily available in most locations. Same advice with regard to leak checks and carbon monoxide still apply.
Gerry
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
